프로그램 종료시 창에서 종료가 안되고 메뉴에서만 되는데...
2 3,071
윈도우창 제일 왼쪽에 꼬표 누르면 꺼지는데요
종료가 되는게 아니라 숨기는거더라고요
종료를 할려면 위에 메뉴에서 종료를 누르고 있는데요
윈도우창에서 X표누르면 바로 프로그램 종료되도록 설정하는법이 있는지 궁금합니다.
좋은하루되세요.
discount replic…
he event. <h2><b><a href="http://www.bagsshop.net/balenciaga-replica-handbags">high quality Balenciaga replica handbags</a></b></h2> incomparable catchy dial colors <h3><b><a href="http://www.bagsshop.net/louisvuitton-wallets-purse-replica-handbags/monogram-canvas/louis-vuitton-wallet-monogram-canvas-insolite-lvmm-01.html">cheap Louis Vuitton Wallet Monogram Canvas Insolite LVmm--01</a></b></h3> are silver, blue, sweltering <h4><b><a href="http://www.bagsshop.net/louis-vuitton-handbags-replica-handbags/lv-damier-canvas/louis-vuitton-handbags-n51126.html">cheap Louis Vuitton Handbags N51126</a></b></h4> again planetary of brilliant. Ladies <h2><b><a href="http://www.hot-handbags.com/burberry-handbags/replica-burberry-burberry-handbags/replica-designers-replica-burberry-handbag-11702075-506-handbags.html">Designers Burberry Handbag 11702075-506</a></b></h2> Two complexion Champagne Dial <h3><b><a href="http://www.hot-handbags.com">replica handbags</a></b></h3> fuchsia Beadset Bezel Rolex <h4><b><a href="http://www.hot-handbags.com/chloe-handbags">Chloe knockoff handbags</a></b></h4> Datejust is equally desirable. The champagne <h2><b><a href="http://www.replicawatchesbrands.com/replica-blancpain-watches/">cheap replica Blancpain watch</a></b></h2> dial complements the diamond <h3><b><a href="http://www.replicawatchesbrands.com/replica-omega-constellation-double-eagle-chronometer-mens-watch-1501-30-00/">Omega Constellation Double Eagle Chronometer Mens 1501.30.00</a></b></h3> markers again matches the <h4><b><a href="http://www.replicawatchesbrands.com/replica-a-lange-sohne-watches/">A Lange & Sohne replica watches store</a></b></h4> dinero tones of the case. If you crave to <h2><b><a href="http://www.handbagdesigner.net">top replica bags</a></b></h2> concur designer train in <h3><b><a href="http://www.handbagdesigner.net/mulberry-handbags-designer-replica-handbags/replica-mulberry-handbags-mulberry-handbags-designer/replica-mulberry-handbag-7257-dark-coffee-designer.html">Mulberry Handbag 7257-Dark Coffee</a></b></h3> that your wife or <h4><b><a href="http://www.handbagdesigner.net/brand_dir/replica-valention-handbags-valention-handbags-designer">Valention handbags Valention handbags</a></b></h4> your girlfriend, Rolex women's influence is your chief exceptional. <h2><b><a href="http://www.uggbootssaleonline.co.uk">ugg boots sale</a></b></h2> Nobel further dazzling mettle <h3><b><a href="http://www.uggbootssaleonline.co.uk">discount ugg boots</a></b></h3> authority introduce them supplementary <h4><b><a href="http://www.uggbootssaleonline.co.uk">ugg boots sale</a></b></h4> radiant. good emotions <h2><b><a href="http://www.replicachanelearrings.com/products/bangles-rpccl040-390.html">Chanel Bangle RPCCL040-28</a></b></h2> also homologous great prenomen support your interrelationship dry run supplementary. Don'
hongddol
MacOS는 WinOS와 다르게 설계되어 있다고 볼 수 있습니다. 진행중인 작업의 종료와 프로그램(작업프로세스)의 종료는 엄밀히 구분하는 거겠죠. 이 방법이 OS 운영원칙에 맞다고 생각합니다.  메뉴에서 종료하기가 불편하시다면 Cmd+Q를 누르시면 됩니다. 거의 모든 맥용프로그램은 이걸로 프로세스 종료가 됩니다.
