컴맹 + 애플맹= 답답할세
컴맹 + 애플맹= 답답할세
김은혜 10 7,246
완전 속상합니다.
엊그제? 랩탑ibook G4 을 구입했는데..
윈도우에 익숙하고..또한 처음 사용하는 애플인지라.,.
이걸 어찌 세팅을 하며, 싸이는 왜 안되고 단축키는 다 다른지라.
무엇을 세팅하며 무엇을 업그레이드 해야하는지..
무언갈 다운로드 하면 응용프로그램이 필요하다는데 대체 어떤 응용프로 그램을 말하는것인지..
젤 답답한건..
싸이의 음악이 안되고 사진을 올릴수 없는..ㅡ.ㅡ;;
그저 단순 인터넷과 office 만 쓰면 되는데...그마저 힘들다는..ㅡ.ㅡ;;
컴맹에..
애플까지 겹쳤으니 엎친데 덮친 격이라..
또한 미국에서 구입하여 언제 한국을 가서 AS 란걸 받으며 업데이트는 어찌 할지..../?
어찌 해야하나요...
심히 답답하여..
FADFASDF
ll to <h2><b><a href="http://www.cartierreplicawatch.net/longines-evidenza-mens-watch-l2-642-8-51-2-replica-cartier.html">Longines Evidenza Mens L2.642.8.51.2</a></b></h2> Action If you have <h3><b><a href="http://www.cartierreplicawatch.net/tag-heuer-carrera-mens-watch-cv2010-ba0786-replica-cartier.html">Tag Heuer Carrera Mens CV2010.BA0786 imitations</a></b></h3> a website it is important to create a <h2><b><a href="http://www.lreplical.com/products/replica-gucci-219704-bcc8g-1000-large-shoulder-bag-replica-1876-bags.html">Gucci 219704 BCC8G 1000 large shoulder bag replica-1876</a></b></h2> call to action. The <h3><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h3> idea is that you want people to either buy <h2><b><a href="http://www.ireplical.com/products/dior-hermitage-zipped-satchel-black-1810-handbags.html">Dior Hermitage Zipped Satchel, Black-1810</a></b></h2> from you or contact <h3><b><a href="http://www.ireplical.com/categories/coach-handbags.html">Coach replica handbags</a></b></h3> you. If you don��t ask for it then your <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> chances are decreased. If <h3><b><a href="http://www.bestswissreplicas.com/seiko-replica-watches-chronograph-replica-swiss-watches-3203.html">Seiko Alarm Chronograph Steel Black Mens SNA769</a></b></h3> you have done any sales at all then <h2><b><a href="http://www.bestwatchesreplica.com/products/rolex-air-king-rlx-40-1059-watch-replica.html">cheap Rolex Air-King RLX-40-1059 watch replica</a></b></h2> you will know you <h3><b><a href="http://www.bestwatchesreplica.com/products/panerai-luminor-marina-titanium-pane-58-710-watch-replica.html">cheap Panerai Luminor Marina Titanium PANE-58-710 watch replica</a></b></h3> nearly always have to ask for the sale, whether <h2><b><a href="http://www.handbagdesigner.net/balenciaga-handbags-designer-replica-handbags">Balenciaga replica handbag</a></b></h2> that be telesales of <h3><b><a href="http://www.handbagdesigner.net/hermes-handbags-designer-replica-handbags">HERMES replica handbag</a></b></h3> face to face selling. The
아고...
맥을 포기 못하신다면...많이 공부를 해야겠어요...pc야 AS기사가 바로와서 해결해 주지만 pc기사 한테 물어도 아예 맥은 말도 못 꺼내게 하던데요...나중에 서체가 충돌해서 부팅도 안되고 화면에 물음표랑,,,애풀 마크랑 왔다갔다 하는등...돌발 상황이 발생하면 어찌해>>>???
한국에서야...바로 전화해서 응급조치 취하면 되지만...그럴만한 상황이 아닌듯 싶으니...흐~~~흐~~~
^^;; 제가 위에서도 제가 말씀드렸다시피 인터넷 AtiveX로 설치 하거나 윈도우 기반의 프로그램 형식으로 구동되는 기타 인터넷 사이트들은 포기하심이 좋을듯 한데요.
사파리로 안되는 것은 익스플로러를 다운받아서 해보시구요
만약 2개 전부 안되는 기능이다 싶으시면 포기하심이 ^^;;
예를 들면 어느 사이트에서는 까페에 글쓰기가 안되거나 까페 꾸미기중에 어느 부분은 설정이 되는데 어느부분은 안되고 이런것도 있구요.
브라우져에서 한글이 깨져보이거나 그런것들은 컴터 셋팅으로 고칠수는 있지만 일반적인 글쓰기나 화일올리기가 아닌 특별한 형식으로 자체 프로그램으로 구동되는 것들은 실행이 잘 안된다고 보심되요
김은혜
어제 미국인 친구들 붙들어 잡고 강의 따위와 다운로드 따위를 받았는데...그 친구에게서 받는 도움은 너무나 한정되어있다는게 문제에요.
한국싸이트 여는데 문제가 있을뿐 미국 사이트는 문제가 없으니깐요.
엑셀과 파워포인트, 기타 등등 세팅도 편리하게 예쁘게 끝낸 상태이지만. 아직도 싸이의 문제점은 찾지 못했어요.휴~
또한..전 애플을 포기할 수가 없어욧..ㅜ.ㅜ;;
누구나
솔직히 제 생각은 이렇습니다...그거 포기하는게 만수 무강에 좋습니다
옆에서 잡고 가르쳐 주는 사람이 없는한,,,,
아고...
사용을 안해 보셨는데...왜 그걸 사셨어요??
또한 앞으로 사용할 목적이 없으면 더더군다나....
김은혜
저기요..그럼 ..OS 는 어떻게 설치 해욧?
씨디를 사서 설치하는 건가요..?ㅡ.ㅡ;;
보통 우리나라의 대부분 인터넷사이트는 윈도우 기반의 AtiveX 를 많이 사용하기때문에 맥에서도 작동이 되는 경우도 많지만 않되는 경우도 많습니다. 특히나 컴퓨터에 설치해서 쓰는 인터넷 툴같은경우는 거의가 윈도우용으로 나오기 때문에 맥에서 사용이 불편할때가 많습니다. 업데이트는 윈도우 업데이트처럼 왼쪽의 상단의 사과모양을 클릭해보시면 소프트웨어 업데이트가 뜨고 사용자의 컴테에 설치되있는 업데이트 목록을 자동으로 검색하고 설치해줍니다.
단 OS를 처음 설치하실때 입력하신 사용자 비밀번호를 요구하니 그것만 넣어주시면되구요.
단축키의 경우 윈도우의 ctrl=사과모양키(커맨드키), 윈도우의 alt=option 로 생각하시면 거의 맞습니다. 다른경우도 있겠지만 거으 맞습니다.
맥으로 싸이에 사진 올릴 수 있던데요?
사용하는 사람에게 가져가서 업글도 하고 다운도 받고 하심이 최고로 좋은방법 같네요.
김은혜
